Does my build work together?
Do all of the parts of my build work together?
Case: Rosewill REDBONE U3 Black SECC Steel USB 3.0, eSATA, 3x 120mm Fans Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147160
PSU: CORSAIR Builder Series CX430 V2 (CMPSU-430CXV2) 430W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
Motherboard: ASRock H61M-DGS LGA 1155 Intel H61 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157315
Processor: Intel Celeron G530 Sandy Bridge 2.4GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics BX80623G530
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116409
Storage: Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
RAM: Patriot Gamer 2 Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model PGD34G1600ELK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220556
GPU: SAPPHIRE Radeon HD 6670 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready Video Card (11192-22-20G)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102988
DVD Burner: SAMSUNG 22X DVD Burner SATA Model SH-222BB/BEBE - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151244
OS: Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Have I made a rookie mistake or am I good to go and order when I'm ready?
Also: Do I require anything else for the build other what I have included?
Thanks, Richard
3 answers Last reply
More about does build work together
  1. Good to go except that you should note your RAM will run at 1333 MHz unless you use an Ivy Bridge CPU. I would also opt for 1x4 GB of RAM instead of 2x2GB because not many people use that these days, and it would make upgrading to say, an i5-2400 easier, because you will be capped at 8 GB RAM if you use 2 GB sticks instead.
  2. his ice-q 7870 $239
    http://www.newegg.ca/Product/Produ [...] 6814161404
    h77 mobo $74.99
    http://www.newegg.ca/Product/Produ [...] 6813135306
    I5 3570 $214
    http://www.newegg.ca/Product/Produ [...] 6819115233
    2x 4gb gskill ares $43.99
    http://www.newegg.ca/Product/Produ [...] 6820231544
    rosewill capstone 450W gold $69.99
    http://www.newegg.ca/Product/Produ [...] 6817182066
    90gb ocz ssd $69.99
    http://www.newegg.ca/Product/Produ [...] 6820227757
    seagate 750gb 7200rpm hdd $59.99
    http://www.newegg.ca/Product/Produ [...] 6822148702
    slverstone tj-08 $109
    http://www.newegg.ca/Product/Produ [...] 6811163182
    lg dvd burner $18.59
    http://www.newegg.ca/Product/Produ [...] 6827136247
    120mm fan $9.99
    http://www.newegg.ca/Product/Produ [...] 6811999346
    $800 build (Canadian) min spec I'd recommend for a good gaming rig
    So can I just use 1 x 4GB 240-Pin DDR3 SDRAM DDR3 1333?
    Would 1 stick of RAM work?
New Build Systems Product
