i5-3750k (Hyper 212 oc to mid 4ghz)
Gigabyte z77X-UD3H
MSI Power Edition GTX 670 (can be oc to above 1400mhz, but oviously set lower for normal use)
Samsung 30mm low voltage 8GB RAM
1TB WD Black
850w Corsair Bronze
NZXT Phantom
I know my power supply is overkill, but I've heard it could be future-proof for future builds. But I was expecting to SLI in the future, but that TX850 is only 125$, for bronze and 850w is a pretty good deal. the TX750w is not bronze, and is 15$ cheaper.
Thanks.
Gigabyte z77X-UD3H
1TB WD Black
850w Corsair Bronze
NZXT Phantom
Thanks.
