You'd actually use one cable to connect two switches.
The port is called an "Uplink" port that you use to connect the second switch to the first. Maybe "chaining" is also a term you are looking for. Many new switches these days have auto-sensing ports that can use any port as an "uplink" port. Or have a little switch to turn uplink port on and off.
