Need 120mm chassis fan that asus fan expert will monitor
SilverStone Temjin Series TJ08B-E
Front 1 x 180mm AP181 intake fan, 700/1200rpm,
18/34dBA (backwards compatible with 140mm fan)
Rear 1 x 120mm fan slot (option)
ASUS P8Z68-M Pro LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard with UEFI BIOS
1 x Chassis Fan connector(s) (4 -pin)
1 x Power Fan connector(s) (3 -pin)
2 answers Last reply
More about need 120mm chassis asus expert monitor
  1. Any chassis fan will work. If you use a regular fan, it will blow at full speed even if connected to the MoBo. If you use a PWM fan, your MoBo can control its speed.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835186033
    That is the cheapest PWM fan I could find at Newegg.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835200051
    That is the cheapest non-PWM fan.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835186036
    I personally like this fan is a bit on the pricier side. I also like Scythe fans in general.
  2. great info
    thank you very much for your advice
    I purchased http://www.nzxt.com/new/products/case_fans/fz-120mm_nonled
    but due to connections could only use the Molex connector and therefore could
    not view the fan in BIOS.
Homebuilt Asus Fan Systems Product
