I have been putting together a new build for a friend tonight and have run across a problem.
On powering up the machine I get a repeated short beep every 3 seconds. According to the site below it could be a power failure.
http://forum-en.msi.com/faq/article/bios-beep-codes
The power seems to work on nearly everything, the optical, the lights, fans, case leds etc
The only issue is the graphics card which only one of the three fans seems to work. Ive connected the card using both 6 pin connectors and fully inserted it into the pcie slot.
I researched before I got him these parts and the power supply should be fine but maybe its too little power or a faulty supply? I tried unplugging the ssd and network card (which doesnt fit anyway!)
Maybe something on the gpu is faulty although I tried this in my machine recently and it worked great.
the items in the build are;
gpu - 6950 gb
ssd - 64gb corsair
network card - http://www.aria.co.uk/Products/Networking/Wireless/Wireless+Adapter+-+PCI%2FPCI-E+Cards/TP-Link+300Mbps+Wireless+N+PCI+Express+Adapter+%5BTL-WN881ND%5D+?productId=47499
optical - http://www.aria.co.uk/Products/Storage/Optical+Drives/DVD+Readers+-+SATA/Samsung+SH-D163C%2FBEBE+SATA+16x+DVD-ROM+%28Black%29+-+OEM+?productId=44562
hard drive - http://www.aria.co.uk/Products/Storage/Hard+Drives+-+Internal/3.5+Inch+SATA+Drives/160GB+-+600GB/500GB+Seagate+Barracuda+ST500DM002+3.5%22+SATA+III+Hard+Drive+?productId=46054
case - http://www.aria.co.uk/SuperSpecials/Other+products/AeroCool+Sixth+Element+Black%2FBlue+Midi+Tower+Window+Gaming+Case+?productId=50819
cpu - http://www.aria.co.uk/SuperSpecials/Other+products/Intel+Core+i3-2100+3.10GHz+%28Sandybridge%29+Socket+LGA1155+Processor+-+OEM+?productId=50439
cpu cooler - http://www.aria.co.uk/Products/Components/Coolers+-+Air/CPU+Coolers/Cooler+Master+Hyper+TX3+EVO+Quiet+CPU+Cooler+?productId=47249
mobo - http://www.aria.co.uk/Products/Components/Motherboards+-+Intel/Socket+1155+-+Intel+B75/MSI+B75MA-P45+Intel+B75+Socket+1155+DDR3+PCI-Express+Motherboard+?productId=50392
psu - http://www.aria.co.uk/Products/Components/Power+Supplies+-+PSUs/Non-Modular+650W+or+less/530W+be+quiet%21+PURE+POWER+L7+80PLUS+Power+Supply+?productId=49506
ram - http://www.aria.co.uk/Products/Components/Memory+-+RAM/DDR3/Dual+Channel+-+%281600MHz%29/8GB+Mushkin+Enhanced+BlackLine+Frostbyte+%23996995+%282x4GB%29+1600+%28PC3-12800%29+240-Pin+DDR3+SDRAM+CAS+9-9-9-24+1.5V+?productId=44336
Been tearing my hair out for hours over this so any help would really be appreciated!
thanks in advance
gpu - 6950 gb
ssd - 64gb corsair
thanks in advance
