Tom's Hardware > Forum > Computer Peripherals > Other Peripherals > Problem transferring files to CompactFlash card
Forum Computer Peripherals : Other Peripherals - Problem transferring files to CompactFlash card
Running W2K-SP4. Using Kingston 256MB CompactFlash Card in SanDisk ImageMate reader/writer. Everything is properly installed. I cannot transfer files to the CF card while within W2K. I get a "No" icon, a circle with a slanted line through it, al la No Smoking. But the odd thing is when I call up the W2K Command Prompt I can copy files to the card. Can anyone tell me how to enable file copying (transfer) while in W2K.
Sponsored Links
Have you figure out the problem?
I use a 9 in 1 compact flash reader under w2k and everything works fine.
here is the link if you are interested:
http://iocombo.com/product/showpro [...] SHPRO9USB2
Reply to d0z
There are 1360 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
