Solved
What power supply should i get?
im not sure what power supply to get, i was going to get something very cheap with 900w or so for around $20, but i heard dont go for anything cheap since a psu is extremely important.
specs:
cpu: i3 3225
hdd: WD 1TB
mobo: MSI Z77A-G41 Z77
gpu: Gigabyte GV-N65TOC-2GD 2GB GTX650
case: Coolermast SGC1000
will these be sufficient? i heard to go for antec or corsair, i live in aus, so i cant get anything from newegg.
i was thinking:
Antec vp 550w or 650w
antec neo eco 520w or 620w
corsair vs650w
or something else?
thankyou!
1 answer Last reply Best Answer
More about what power supply
  1. Best answer
    you should first check the amount of watts you will need by this website
    http://www.coolermaster.outervision.com/
    there are many website can do the calculation.
    Then, choose the brand you want by checking the reviews on youtube or here :)
Power Supplies Antec Components
