Sign-in / Sign-up
GeForce GTX 560 Ti - WHAT PSU HELP!
  • Graphics Cards
  • Graphics
Last response: in Graphics Cards
July 6, 2012 8:00:33 AM
I have searched all forums and things but for what i need to know none helped :(
So basically after spending about £200 on this killer Graphics Card, I now find i need a better PSU :p
My PSU is 320W which is no where near as much as i need!
This is not a question about what Wattage i need, Because doing research i know i need at least 500W, Now being myself i have decided to seek a 650W PSU...But now i am all confuddled about wtf connectors i need!
I am also aware that i need 2 6 Pin connectors? i am not a hardware wiz though so...
I am on quite a strict budget for my PSU (as i just spent a lot on the card) I was looking at this one
http://www.amazon.co.uk/CiT-650W-Power-Supply-Rails/dp/...
Good price, good reviews by the look of it!
That card says it comes with: Silent and Better Ventilation # ATX 12V Compliant for all Types of CPU and Mainboard # 12cm Silent Fan # Dual 12v Rails # CE & PFC Approved Connections: 20+4 Pin Main Connectors: 1 P4 4-Pin 12V Connectors: 1 4-Pin Molex Peripheral Connectors: 5 SATA Connectors: 2 6-Pin PCIe Connectors: 1 Floppy Drive Connectors: 1
Will this PSU be fine to run my card then since it has 650W and 2 6 pins? Please DONT say stuff like 'No crap, buy this' and then give a really expensive one -.- cause i will kill you if you do!
Also final note, as im not a hardware wiz, The PSU doesnt need any specific connectors than normal to power my Computer does it?
More about : geforce gtx 560 psu
July 6, 2012 8:11:29 AM
EDIT: THIS PSU IS UNSTABLE FROM WHAT I HEAR!!!!
IF YOU CAN SUGGEST A BETTER ONE FOR UNDER £50 PLEASE DO!!!!
a c 75 U Graphics card
July 6, 2012 8:36:06 AM
Please mention the graphic card and are u gonna overclock?
July 6, 2012 9:28:31 AM
umm... Says in the title, and i will not be overclocking
