MexicanBandit :
Hey, I'm putting together a build but I am not too sure which Power Supply would be best suited for the system. From some research, I would have guessed around 600-700w but my knowledge in this area is very low.
CPU - Intel i5 3570k
Cooler - Stock
Motherboard - AsRock Z77 Extreme4
Graphics Card - Sapphire HD 7870 GHz Edition 2048MB
Memory - Corsair Vengeance 1600MHz 8GB
HDD - Samsung 5400rpm 1TB HDD
Case - NXZT Phantom 410
Thanks in advance!
My current two builds have Corsair HX series power (650 & 750) supplies and both have worked as expected. However, I feel I have to say this... I have recently had a positively rotten experience with Corsair. Actually, my experience is a multi-level affair. For starters, the company Corsair chose to handle their rebates declined two separate rebates. I've never had a problem with rebates before so I assume that they're just randomly rejecting claims. Had I known I wasn't going to get the $35, my purchasing decision likely would have been different. That's minor compared my next gripe. My Corsair case (a gorgeous 550D) arrived with a broken side panel. I submitted an RMA the day it arrived and here it is 3 weeks later with no replacement part. Previously I was able to view the status of my RMA and see that they received my damaged parts. Currently I'm unable to view details for my RMA and I assume it has been cancelled/deleted. I still believe Corsair makes some fine, fine products, but my experiences with the company means I won't be buying from them again.
Btw, your build looks a lot like my current system... except I went with that big Noctua cooler and SSDs.
