I'm not sure if something's up with my power supply or not. If I turn off my computer, flick the rocker switch on the back of the PSU to off, and wait a few seconds, and turn the computer on, my case lights and fans come on for half a second before turning off. If I wait a minute or even five minutes instead, the case lights and fans remain inactive, but a couple lights (num lock or whatever) do light up on my keyboard for a moment. This only ever works once -- if I try again, nothing happens. So it seems that some residual charge is being kept after I run the computer, which is used next time I turn it on, rocker switch or not. Is this an issue? The PSU is still within an RMA period.
I'm not sure if this is relevant, but it also seems to me that the PSU emits a soft, constant hum when I put my ear right to it that the PSU in my other computer doesn't -- but it could just be the fan, it's hard to tell. My other PSU doesn't have these rocker switch problems, either.
What do you think? Is this abnormal behavior, and is it worthy of a RMA? Thanks.
