Proffessional sound cards
Hello
I know that Creative is the best Brand for a sound cards since the old times of dos and untill the moment!
thinking of proffesional sound card...
Creative has a proffesional sound card which has really really insane high quality everything!
They actually USED 24K GOLD!
only one thing i didnt like!
It was a PCI 2.0 card not PCI express
Is there any professional PCI express sound cards available?!
I have another question that is quite off topic
I have seen something similar to JBOD and external SAS but it was with PCI and Pci express
It was a case having some sort of a board containg only PCI and some chips ,The case have a power supply
that case is connected to the computer via a cable just like connecting a JBOD !
Can someone give me more detailes about this thing?!
Waiting for answers
Thanks
6 answers Last reply
More about proffessional sound cards
  1. Can you provide a link to this card? As the specs for the card don't sound quite right.
  2. well i checked and couldnt find the card
    but...
    i found a new card which is similar but pci express x1
    http://asia.creative.com/products/product.asp?category=1&subcategory=875&product=21383
    is this a good sound card?
    What are the alternatives?
  3. Creative hasn't been a good brand for a LONG time now; they've been passed by HT Omega, Auzentech, and ASUS.
    ASUS is one of my favorites as creative.
    i dont know the other two.
    can you give me some links to their products?
    Thanks
  5. I have seen something similar to JBOD and external SAS but it was with PCI and Pci express
    like
    http://www.youtube.com/watch?v=Vev_yRdYVwM
    Thanks
    Auzentech:
    Forte (X-fi): http://www.newegg.com/Product/Product.aspx?Item=N82E16829156010
    Bravurua (X-fi): http://www.newegg.com/Product/Product.aspx?Item=N82E16829156015
    Meridian 2G (CMI-8788): http://www.newegg.com/Product/Product.aspx?Item=N82E16829156002R
    HTHD (X-fi): http://www.newegg.com/Product/Product.aspx?Item=N82E16829156014
    HT Omega (All CMI-8788 based):
    Claro Halo: http://www.newegg.com/Product/Product.aspx?Item=N82E16829271004
    Claro II: http://www.newegg.com/Product/Product.aspx?Item=N82E16829271007
    eClaro: http://www.newegg.com/Product/Product.aspx?Item=N82E16829271006
    Claro Halo XT: http://www.newegg.com/Product/Product.aspx?Item=N82E16829271005
    For the most part, HT Omega uses the same chipset (CMI-8788) ASUS uses. Auzentech used the CMI-8788 for a few of its older cards and the Meridian, but otherwise used Creatives own X-fi chipset with significantly upgraded components. Both are a bit overdue for a product refresh though...
Sound Cards PCI Creative Components Product
