nimbah_52 Distinguished Oct 9, 2011 127 0 18,710 Jan 9, 2013 #1 I have a HP DX225 Amd Athlon 64 x2 4800+ DVD drive 1 Sata Drive 250 watt power supply I want to get a cheap graphics card, the HD6450. Would it be able to run on this power supply?
X Xttony Distinguished Mar 4, 2011 1,658 0 20,160 Jan 9, 2013 #2 Better get a HD 5450 or the HD 7750. Although it says that HD 7750 need more than 350watts but you will be fine.
T TheDocGG Honorable Dec 8, 2012 80 0 10,660 Jan 9, 2013 #3 Although it might run, I wouldn't recommend it. For that system you are probably talking in the region of a 500W psu: This is reportedly one of the best at that range, without parting with alot of cash: http://www.overclockers.co.uk/showproduct.php?prodid=CA-053-BQ
G GhislainG Titan Jul 16, 2008 23,962 5 74,965 Jan 9, 2013 #4 TheDocGG : Although it might run, I wouldn't recommend it. For that system you are probably talking in the region of a 500W psu: This is reportedly one of the best at that range, without parting with alot of cash: http://www.overclockers.co.uk/showproduct.php?prodid=CA-053-BQ It now runs on a 250W PSU and it draws much less than that; therefore adding a low-power video card can't require a 500W PSU. Xttony's recommendations make sense.
