Archived from groups: alt.cellular.nokia (More info?)
it appears the phone has most of its functionality besides being able to
start up the symbian OS fully...
without a sim, emergency calls work fine.
with a sim, the phone boots up, does the nokia shake hands thing, startup
pic appears, followed by the wallpaper, and default screen, but then it
displays NOKIA again and switches itself off...
formatting the phone using the green+3+star button when powering up
completed fine...
any recommendations?
do you think a re-flash of the phone would fix it (temporarilly at least)
>completed fine...
Sounds to me like the battery is farked rather than the phone itself.
> completed fine...
Are you sure it's dried out completely ?
Water damage can cause any number of problems, and often writes the phone
off.
Michael Turner
Email (ROT13)
zvxr.gheare1963@ivetva.arg
yes, positive its dried
"michael turner" <zvxr.gheare1963@ivetva.arg> wrote in message
newsan.2004.09.07.10.04.03.419000@ivetva.arg...
>> completed fine...
> off.
> Michael Turner
> Email (ROT13)
its not the battery. ive tried a known-to-be-good battery
"Niall Leonard" <niall@codology.com> wrote in message
news:tosqj0tm2ojanceb4fpea2k9d4q2p1fr17@4ax.com...
> On Tue, 7 Sep 2004 11:28:14 +1000, "Daniel Juhn"
>>completed fine...
> nl
"Daniel Juhn" <j.u.h.n.remove.the.periods@optusnet.com.au> wrote in message
news:413d0eaf$0$12374$afc38c87@news.optusnet.com.au...
> completed fine...
it's more than likely had it...water damage is "usually" irreversible
hi,
i am looking forward to buy broken/damaged nokia 6600. i don't care
about the condition or damages. even if it is crushed.. all i need is
that it should be really cheap.
if interested.. contact me as Jolly1312@yahoo.co.in
