Hi guys, just thought I'd throw these numbers by you.. Thought this was pretty strange.
Used to have a Cooler Master V6 CPU cooler and got great temps, idle and full load. I recently got my H100i installed, with an additional 2 fans for a push / pull effect. The problem is, I'm getting above 90 degrees Celsius at 100% CPU on Prime95, otherwise idle temps gererally 40+ Celcius. As you can assume, I am pretty concerned about this, already mailed Corsair. Is it possible I'm not configuring something right in Corsair Link?
Thank you in advance for any help or insight you can provide,
Gus
Case: Cooler Master HAF-932 Advanced [Blue Edition]
Motherboard:ASUS P8Z77-VPRO
CPU:Intel i5 3570K OC'd to 4.5ghz
CPU Cooler:Corsair H100i
Ram: G. Skill Ripjaw X Series 16gb (2 x 8gb)
GPU: MSI 660ti PE
Sound Card:Sound Blaster Recon 5.1
PSU: Seasonic 1050W 80+ Gold Certified
SSD: OCZ Vertex 4 128gb
HDD: Western Digital Caviar Black 1tb 7200rpm (x2)
Gus
GPU: MSI 660ti PE
