Best PC Case and Power supply for $200-$240
This is my first build and i have all the components picked out except for the case and power supply.
My specs:
CPU: AMD Phenom II X4
MOBO: MSI 970A
HDD WD
GPU: Radeon HD 6870
Cooler Master hyper 212
I dont care if it is full or mid tower
must look badass and have good airflow basic stuff, lots of blue led fans or non leds
Thank you!
4 answers Last reply
More about best case power supply
  1. Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146087
    PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
    That will be $179. With the difference saved you can upgrade your GPU to a Radeon 7850 or upgrade your CPU to the Intel i5-3450.
  2. thank you very much! i can't tell you how many hours i've been trying to decide these two components.
  3. i rather spend my 250 on a much better GPU and CPU but it is your money
    the phantom 410 also comes in gun-metal if you like that colour. as for the psu, id get a pc power and cooling mk3 600w. only 49.99 after MIR at microcenter
  4. I agree with both g-unit1111 and TheBigTroll, but as you have already got the other parts, then get the new case and psu.
    HD 6870 needs only 500W, with 2 75W 6-pin PCI Express power connectors.
    CORSAIR Builder Series CX500 V2 500W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
    There is this cool case with blue leds, and great air flow COOLER MASTER Storm Sniper http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194
    The case and psu will cost you $179.98, but both offer you $10 in rebate, so it will be only $159.98
New Build Power Supplies Cases Systems Product
