Sorry for asking this question that has no doubt been repeated constantly,
but I'm looking for a computer in which I could play games like, Guild Wars 2 and Final Fantasy 14 on.
I will also be using it for 3D modeling and rendering, the program being 3D Studio Max.
My budget is $2000 for everything.
I attempted to put one together on CyberPower's site here for their Black Pearl - http://www.cyberpowerpc.com/system/CyberPower_Black_Pearl/
And now I'm left wondering if it'll work out well?
Like many others before me, I haven't done this before and I'm unsure of what half of this stuff does but,
I once remember a friend telling me that if the power supply and the motherboard aren't compatible then the computer will overheat and die.
or something to that extent.
So I need to be sure.
At least I can say I attempted to do this, though truth be told I really just went and clicked on what looked good all willy-nilly.
I thank you all in advance for all your help on this matter.
Case: Cooler Master Storm Trooper Full Tower Gaming Case w/ 200mm Fan, Integrated Fan Controller, Front USB 3.0 & X-Dock, and Easy Carry Handle [+4]
Internal USB Extension Module: NZXT Internal USB 6-PORT Expansion Module [+19]
Extra Case Fan Upgrade: Maximum 120MM Case Cooling Fans for your selected case [+9]
Noise Reduction Technology: Anti-Vibration Fan Mounts [+9]
CPU: Intel® Core™ i7-3820 Quad-Core 3.60 GHz 10MB Intel Smart Cache LGA2011 (All Venom OC Certified)
Performance Tuning Protection Plan by Intel: Intel® Core™ i7-3930K Performance Tuning Protection Plan by Intel [+39]
Venom Boost Fast And Efficient Factory Overclocking: Pro OC (Performance Overclock 10% or more) [+19]
Cooling Fan: CyberPower Xtreme Hydro Liquid Cooling Kit 360MM w/ Triple Fan(CPU & GPU Liquid Cool Capable, Extreme Overclocking Performance + Extreme Silent at 18dBA) [+93]
Coolant for Cyberpower Xtreme Hydro Water Cooling Kits: High-Performance Coolant powered by Koolance [+19] (Clear Color) (it sounded like a good idea)
Motherboard: (3-Way SLI Support) ASRock X79 Extreme 4 Intel X79 Chipset Quad Channel DDR3 ATX w/ UEFI bios, XFast LAN, Charger, & USB Technology, 7.1 HD Audio, GbLAN, USB3.0, SATA-III RAID, 3 Gen3 PCIe X16, 2 PCIe X1 & 2 PCI [+17]
Memory: 16GB (4GBx4) DDR3/1600MHz Quad Channel Memory [+86] (Patriot Viper 3 Intel Extreme Masters Edition [+32])
Video Card: AMD Radeon HD 7850 2GB 16X PCIe 3.0 Video Card (Major Brand Powered by AMD)
Power Supply Upgrade: 800 Watts - Standard Power Supply - SLI/CrossFireX Ready
Hard Drive: 1TB SATA-III 6.0Gb/s 32MB Cache 7200RPM HDD (Single Drive)
Data Hard Drive: None (don't know what this is)
Hard Drive Cooling Fan: Vigor iSURF II Hard Disk Drive Cooling System [+21] (1 x System)
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
LCD Monitor: 22" Widescreen 1680x1050 TFT Active Matrix LCD Display [+148]
Network: Intel Pro Gigabite 10/100/1000 Network Card [+34]
Wireless 802.11B/G Network Card: PCI Wireless 802.11n 150Mbps Network Interface Card [+19]
IEEE1394 Card: None (no idea what this is either)
Internal USB Port: Internal USB 3.0 4-Port Hub [+29]
Sincerely,
- Montacue
Sincerely,
- Montacue
