Solved
Third Monitor (Mini Display Port, Display Port Problem)
  • Graphics Cards
  • DVI
  • Cable
  • Monitors
  • Graphics
  • Displays
July 7, 2012 8:33:00 PM
Hey, I have got a Hd 6950(2x minidisplay port 2x DVI port 1x HDMI port) graphic cards. And I have got a three monitor. I want to active it all.
I learned to need an active minidisplay port to vga or minidisplay port to dvi cable. Here's my problem. I want to buy minidisplay port to dvi but my country doesn't have it but I can find display port to active dvi cable.
I have a minidisplay port to display port cable. If I buy Sapphire ACTİVE DP TO SL-DVİ CABLE will my third monitor work? I mean I will plug mini display port to display port cable first and after I will plug active dp to dvi cable.
Will it work? If someone help me I will be very grateful.
I have this
http://estore.circuitassembly.com/product_images/r/044/...
And I will buy this
http://ecx.images-amazon.com/images/I/81%2BrZUAlqTL._AA...
After this processing Will my third monitor work with eyefinity?
Sorry for my English. I hope you will understand me. Take care.
More about : monitor mini display port display port problem
Best solution
a b U Graphics card
a b C Monitor
July 7, 2012 9:29:09 PM
Should work just fine. All the mini adapter does is turn it into a standard display port so there is no signal processing going on. As long as your second adapter is active you should have no problems.
July 7, 2012 9:30:20 PM
Best answer selected by muhsing.
m
l
