Hi guys, I'm close to finishing my computer finally, just one little step to take (I hope) - the GPU (7850).
The problem is that I have two PCI-Express slots on my motherboard (Intel DBZ77BH-55K Desktop Board), one of which is positioned too close to the CPU heatsink IMO.
Apparently I have made an error while installing the Scythe Samurai ZZ, as I had to rotate it by 180° from its current position, so that the heat pipe endings are turned upwards. Since the running temperatures are very good IMO (32°C average on idle, 67°C after 6 hours of prime95), I really don't feel like re-installing the heatsink, of course, if I don't need to. Then again, if I rotate it, I will have more clearance for the GPU.
The two PCI-Express slots I have are labeled as PCIe x16 (the one closer to the CPU) and the PCIe*x16 (x8 electrical). Can I simply plug in my new graphics card into the second slot and be done with it?
Here is a picture describing my problem:
Here's an article describing the "issues" related to the heat pipe orientation...
http://www.legitreviews.com/article/741/1/
Thank you guys in advance for any insight or opinions
