Approximate Purchase Date: this week
Budget Range: 1100$ (I have used 300$ so I have 800$ left)
System Usage: Gaming( Shogun 2: Total War, Arma 2, Battlefield 3, Mount & Blade, Crysis 2, and Skyrim)
Are you buying a monitor: No
OS: No
Preferred Website for Parts: Newegg
Country: USA
Parts Preferences: None
Overclocking: Yes, 4.0 - 4.5
SLI or Crossfire: No
Parts not needed: Monitor(1920x1080), Case(HAF 912), RAM(8gb 1600), Dvd Drive, PSU (Corsair CX600)
Try to keep right at or under 800$ for the rest of the parts I need, and I would like to know if the parts I'm looking at are good.
CPU:i5 3570k- 229$
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard: AsRock Extreme4 z77- 135$
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
Video Card: Gigabyte 7870- 259$
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125418
HDD: Western Digital Caviar Blue WD5000- 70$
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
CPU Cooler: COOLER MASTER Hyper 212 +- 30$
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Total: 725$
OS: No
Country: USA
CPU:i5 3570k- 229$
Total: 725$
