Hi everyone i wanna build a new PC. Although i had buy some computers before i have little experience on building a system
This are the parts i decided on an they are kinda at my budget limit.
Some parts are cheap so i'm not sure if i made the right choices or i screwed big time.
I want to use the system for gaming an would want to play most of the games out there at high details.
I never done OC but i will probably try it.
Upgrades i can do later(in the following years) would be
-cooling system
-use crossfire with the mentioned video card(probably will need a new motherboard then since although it does has crossfire don't think it's supports this particular setup)
I'm interested if
-everything fits together well(chassis is big enough, parts are compatible),
-what is the bottleneck of this system(what i need to upgrade first)
-all of this will be ordered online so would i have all the "building parts"?(cables, screws..)
-well, any other advice
Intel Core i7-3770K IvyBridge 3.5 GHz box or i7-3770 (don't think i need to link these)
if i get 3770 i could afford a better motherboard
AeroCool VS-4 Window chassis
http://www.aerocool.com.tw/index.php/products/chassis/30-pgsv/121-vs4w
power supply
http://www.kissquiet.com/en/products_all.asp?id=192
AsRocK P67 Pro3 SE Socket 1155 motherboard
http://www.asrock.com/mb/Intel/P67%20Pro3%20SE/?cat=Specifications
HDD WD Caviar Blue LX 1TB SATA3 32MB 7200rpm
http://wdc.com/global/products/specs/?driveID=894&language=1
Sapphire AMD Radeon HD6870 1GB DDR5 256bit PCIe
http://www.novatech.co.uk/products/components/atiradeongraphicscards/amdhd6870series/11179-09-20g.html
2X DDR3-1600 CL9 240-Pin DIMM Kit 1600 for a total of 16gb
http://www.valueram.com/datasheets/KHX1600C9D3K2_8GX.pdf
-cooling system
I'm interested if
power supply
