Greetings,
I have put together a list of parts for my first gaming PC but would love someone to double check it for me. I don't know too much so I'm not sure if all the parts are compatible.
Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119256
Optical - http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Hard Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Graphics - http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
Power - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131832
Processor - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Extra fan - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Comes out to $1,018. I'd like to keep it around that. But I can go up a little bit if it's worth it. I'll mostly be running games like WoW, maybe some BF3 or other FPS. I don't need to be running Crysis 2 on ultra but I want to run WoW on max and be able to to most others on at least high/ultra.
I am not too sure about the graphics card or the motherboard. Any suggestions/improvements would be appreciated!
Thanks.
Thanks.
