Are these parts compatible?
Hi there I'm building my first gaming rig and just wanted to know if these parts are compatible?
CASE- Coolmaster HAF 932 Advanced
MOBO- Asrock Z77 Extreme4-ATX-LGA1155 socket
CPU- Core i5 2500k
GPU- EVGA Geforce GTX670
RAM-Corsair Vengance 8GB DDR3 DIMM240pin
HDD- Seagate Barracuda 2TB Serial ATA-600 3.5" 7200rpm st200DM001
SSD- OCZ Agility series 60GB
PSU- Thermaltake Smart Power Series 750watt modular 80+ Bronze
Any help would be appreciated thanks.
3 answers Last reply
More about parts compatible
  1. I had that 60gig ssd and to be completely honest i would really recommend you go with either 2 or a 120gig ssd. The agility drives are just fine there is really no reason to pick any manufacturer over another at the moment, OCZ has the fastest most reliable drives as far as i have seen and experience. You are going to have lemons with any company, there is no perfect choice, OCZ is closer to the top rung of the ssd makers.
  2. Step down the case to a 922. Get a 3570K if it's not too much more. Get an MSI or ASUS 670. Better coolers on those. Don't get the Agility drive. Get a 90GB Crucial or Samsung drive. Don't get a Thermaltake PSU.
  3. They use Sandforce controllers which aren't as good as Marvell. The updates are destructive. So, spend a bit more and get the Crucial or Samsung. But, OCZ drives are fast.
New Build Compatibility Systems
