Im building my own rig, and I need abit of help. I have found all the parts I want, and im pretty sure they are compatible with each other, but if anyone here has any tips or can check if everything is ok, that would be great Here are the specs, and links to the parts.
Processor: AMD FX-8120 Zambezi 3.1GHz
Ram: 8 GB DDR3 (x2, 4 GB sticks)
Graphic card: SAPPHIRE Radeon HD 6850 1GB 256-bit
Hard drive: 1.0 TB 7200 RPM 64MB Cache SATA 6.0Gb/s
Motherboard: ASRock 970 EXTREME3 AM3+
Case: Rosewill CHALLENGER Black Gaming (3 fans)
Power supply: CORSAIR CX600 V2 600W
CD drive: ASUS 24X DVD Burner
Processor: $160
http://www.newegg.com/Product/Produc...82E16819103961
Ram: $39
http://www.newegg.com/Product/Produc...82E16820231314
Motherboard: $85
http://www.newegg.com/Product/Produc...82E16813157280
Hard drive: $90
http://www.newegg.com/Product/Produc...82E16822148840
case: $50
http://www.newegg.com/Product/Produc...82E16811147153
Graphic card: $150
http://www.newegg.com/Product/Produc...82E16814102908
Power supply: $70
http://www.newegg.com/Product/Produc...82E16817139028
CD drive: $20
http://www.newegg.com/Product/Produc...82E16827135204
Total: $663.92
Also if im missing anything could you points that out? XD And what else would I need, on the lines of cables and cords.
O and Im willing to add about $15 to any of these parts to improve them... but i would like to stay below $750.....
Processor: $160
Ram: $39
Motherboard: $85
Hard drive: $90
case: $50
Graphic card: $150
Power supply: $70
CD drive: $20
Total: $663.92
