Help with Zotac GT 520 2gb
Hello guys please help me I recently brought a Zotac NVIDIA GT 520 2GB from a store and now i have installed it and according to zotac the graphics card must have the following specs
http://www.zotac.com/index.php?pag [...] 57&lang=en
Chipset Manufacturer NVIDIA®
GPU GeForce® GT 520
Core clock- 810 MHz
Stream Processors- 48
Shader Clock -1620 MHz
Memory Clock -1066 MHz
Memory Size -2GB
Memory Interface- 64-bit
Memory Type- DDR3
Memory Bandwidth- 14.4 gbps
OK everything is fine buy when i open gpu z it shows that my memory clock is 533mhz and memory bandwidth is 8.5gbps
So I am confused totally what to do because it is showing the half of the memory clock i should have and half of the memory bandwidth so please help me because half memory banwidth means half performance.
Thanks.
Please Reply soon.............. :D  :D  :D  :D  :D  :D
More about : zotac 520 2gb
Ask the community
