First PC Build (new) Need advice
Last response: in Systems
August 27, 2012 10:56:07 PM
So I'm going to build my first computer at the end of the year and I think I have a build. It's about $750, so if you could tell me if I'm missing any components (btw, I have a mouse/keyboard/monitor).
Case: Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
Mobo: ASUS M5A97 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
PSU: CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
CPU: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
GPU: SAPPHIRE Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card (100314-3L ) (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
HDD: Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
Case Fan: (Maybe more than 1) Scythe SY1225SL12M 120mm "Slipstream" Case Fan (http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
If you think this will be a semi-good build or if I could upgrade a few parts, I don't think I want to spend over $850. Thanks for any responses.
More about : build advice
August 27, 2012 11:00:17 PM
The mobo and CPU are incompatible....
m
l
August 27, 2012 11:01:38 PM
Alright, any mobo you would recommend that is around the same price?
m
l
August 27, 2012 11:19:31 PM
Okay thanks so much, if you don't mind me asking, why would the Motherboard that I had chosen not work with the CPU? And does everything else look pretty good?
m
l
August 28, 2012 12:40:38 AM
Just look at the name.
Your CPU is Intel. Now, do you think they'd be compatible? Looks good, but spend a bit more and get the 7850. It's beast of a GPU and better-performing.
m
l
