About to buy parts (compatibility check)
After about a month of research and picking parts, I think im ready to build my first gaming computer.
If any of these parts will cause compatibility issues or are a bad brand or something please make a suggestion.
Optical drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118067
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156063
Hard drive/SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233223
PSU (is 620w enough I may be upgrading parts in the future)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
GPU/Ram (borderlands 2 free thanks Nvidia!)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1036619
CPU/MOBO
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1030095
External parts ( if you want you can reccomend your speakers or whatever)
Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236102
Keyboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16823126194
Speakers: http://www.newegg.com/Product/Product.aspx?Item=N82E16836121014
With windows 7 it will cost $1,476.87
Also if anyone could give me some advice for building i would love to hear it.
2 answers Last reply
More about about parts compatibility check
  1. None of your links are working. Use PC Part Picker or list the items individually. The CPU and motherboard are good choices.
    Ya i noticed that after i posted they should be working now. :)
New Build Compatibility Systems Product
