The Build
Motherboard: Tyan FT72-B7015
Processor: Dual Xeon X5680
RAM: 144GB
Hard Drive: OCZ Vertex III
GPU: 8X Zotac GTX 680 2GB
I have installed every driver version provided by NVIDIA and I'm continuing to have problems initializing the 8th GPU. The GPU's are all operational and can be moved to any slot and function properly. There is no OC'ing with any of the GPU's. Windows recocognizes all 8 GPU's however it is disabling the one on PCI Bus 12? Computer managment says there is a problem and giving Code 43 (worthless info) and disabling hardware. When installing different driver versions the PCI Bus that gets disabled can switch to different GPU's. This makes me believe that it could be a driver issue with NVIDIA. Is there any BIOS settings that could prevent 8 GPUs from operating properly? Does anyone have any suggestions that I could try? I'm going to round up 8 Tesla C2070's to see if those work. It could be a problem with the new GTX680.
RAM: 144GB
