I RMA'd my Toxic 6950 a couple weeks back (still in the RMA process) because I was experiencing artifacts on the display. They appeared in the form of green flashing dots in random places, sometimes there are red dots to. This happens in the BIOS and in the OS and it's worse in the OS when there are no graphics drivers installed.
My plan was to use the built in graphics of my 2500K while I was waiting on my replacement. But when I tried I just got major corruption on the screen. I could barely see what was going on. It was all green and blocky. It happens when the CPU is running at stock settings to.
Today I borrowed my brothers Toxic 6870 which we know works absolutely fine. I'm getting the exact same problem. So I can rule out graphics cards as the problem now.
Sometimes it's not that bad. I can barely see any corruption happening right now in this Firefox window. It's usually at it's worst when you have a window on the screen. If I move a window around the screen the flashing dots will move with the window.
I don't think it's the monitor either because the problem is so much worse when I use the 2500K's built in graphics, so much worse...
* So it's something other than the graphics card which is the problem.
* It's not a driver issue because it happens in the BIOS also. Though it is much worse in the OS when there is no driver installed.
* Does not appear to be a monitor fault.
Updates to this post:
Things I have tried so far:
*Tried every BIOS going for my Motherboard.
Other problems found:
*It says "AMD Catalyst not available" in CCC. It did this with both cards.
I'm thinking it's the CPU somehow. But is it possible for the CPU to cause artifacting through the PCI-E GPU?
Really hope you guys can help me figure this out. I've already sent off a graphics card which I now think was probably ok. Really want to figure this out before my next move. Thanks people...
