OCZ ZS Series Power supply - 750 Watt enough?
Last response: in Components
Is a OCZ ZS Series Power supply - 750 Watt enough for a 7770 crossfire(yeah i know i should just get a higher single gpu but i just wanna try the crossfire setup) and I'm also planning to add 2 120 SSDs in the future without any issue?
I currently have a 500w psu and it doesn't support Xfire so I really need to upgrade it
My PC specs:
AMD FX-6100
Arctic Cooler 7 rev2
8GB ram 1333mhz
Asus M5A97
Seagate 1TB HDD
Powercolor HD7770 1GB ghz ed
3x120mm fans
the other 7770 card is an Asus hd7770 2gb ghz with dual fan
Related ressources
Sell your 7770 then get a 7870 then Xfire that in a year when you get some more money. I would say you shouldn't xfire anything lower than a 7850 2gig model at this point even that's not a good idea. however you could sell your 7770 then buy a 7850 now ifyou don't have the money for the 7870.
My PC specs:
AMD FX-6100
8GB ram 1333mhz
Asus M5A97
Seagate 1TB HDD
3x120mm fans
That power supply is will be fine
Im using ocz zt 750w fully modular power supply
Dont get the ocz zs get the ocz zt
it the same price
only zt is better cause you get better air flow, nice cable management, save power, ETC
:D
