Onboard radeon 4200 This device cannot start (Code 10)
  • Radeon
  • Devices
  • Graphics
July 9, 2012 10:33:20 PM
no matter what this device can not start and will not reinstall.
I have a motherboard with a radeon 4200 built into it (integrated) but right now I am using a (plain) pci diamond something (no gpu in the card straight from the early 90s pentium 1 computer).
Reason for this is... I had some strange problem one day while playing slashem (a very low graphics intensive game) in which the whole screen locked up 30 seconds later went black and then my monitor said no signal. I have absolutely no idea why. The board is just a bit less than 2 years old. I did not change anything, or update drivers, and windows XP is ALWAYS set to never update. The only thing I installed recently was a friends copy of a super high end graphics game that was a bit to resource intensive for this computer to run smoothly, and I uninstalled it anyway after it barely ran.
Everytime I try and uninstall and then reinstall the drivers
(it has been rolled back first but that didn't work)
it either crashes to blue screen of death while trying to install the file ati2mtag.sy_ or installs all parts (after I have to search for each one in the AMD_Catalyst_12.4b_Hotfix_XP folder) but then says there is a problem with the installation your device might not work correctly.
In device manager it has (!) yellow icon and it says This device cannot start. (Code 10) in the properties window.
What am I supposed to do with this?
is it possible that in less than 2 years this hardware burned out?
If so then how do I kill it so that it will not try and install for it anymore
(everytime I reboot it tries to install it even though I chose disable device now that I have my blazing non gpu 16 million color and only at 800x600 res vid card running)
Eventually I'll have go to freegeek and get another card unless somehow this onboard one can get working again.
btw everytime I try and install it/uninstall and reinstall it etc...
I reboot and plug the monitor into it only to be reminded by the monitor that there is No Signal.
(edit)
Here is the error log from the catalyst 12.4 reinstall after safe mode driversweeper and reboot
-UI
07/09/12 16:19:35
install
Advanced Micro Devices, Inc.
0x9601
0x1022
0x9601
0x1022
0x060000
0x00
0x9602
0x1022
0x0000
0x0000
0x060400
0x00
0x970f
0x1002
0x970f
0x1002
0x040300
0x00
0x9605
0x1022
0x0000
0x0000
0x060400
0x00
ATI Integrated SATA Support
0x4390
0x1002
0x7501
0x1462
0x01018f
0x00
ATI Integrated SMBus Support
0x4385
0x1002
0x7549
0x1462
0x0c0500
0x3c
0x439c
0x1002
0x7549
0x1462
0x01018a
0x00
ATI Integrated Azalia Support
0x4383
0x1002
0x7549
0x1462
0x040300
0x00
0x4384
0x1002
0x0000
0x0000
0x060401
0x00
0x1200
0x1022
0x0000
0x0000
0x060000
0x00
0x1201
0x1022
0x0000
0x0000
0x060000
0x00
0x1202
0x1022
0x0000
0x0000
0x060000
0x00
0x1203
0x1022
0x0000
0x0000
0x060000
0x00
0x1204
0x1022
0x0000
0x0000
0x060000
0x00
Microsoft Visual C++ 2008 SP1 Redistributable
9.0.30729.4148
6
AMD Catalyst Install Manager
Succeed
8.0.873.0
20
HDMI Audio Driver
Succeed
5.18.0.5512
Hardware information
Existing packages
Packages for install
Packages for uninstall
Other detected devices
Error messages
Name
Manufacturer
Chip type
Device ID
Other hardware
Download packages
Success
Fail
Vendor ID
Class Code
Revision ID
Subsystem ID
Subsystem vendor ID
Catalystâ„¢ Install Manager
Installation Report
Final Status:
Version of Item:
Size:
Mbytes
thats all it said I hope it helps
OH AND PLEASE MAKE PEOPLE LOG IN BEFORE THEY WRITE ONE HOUR WORTH OF TEXT OF THEIR PROBLEM ITS ANNOYING TO HAVE TO QUICKLY MAKE AN ACCOUNT IN ORDER TO POST THE THING YOU JUST SPENT ONE OUR WRITING.
More about : onboard radeon 4200 device start code
July 13, 2012 4:31:09 AM
I did that one already didn't help...nevermind no one can help
m
l
