Yes No
Ads
Tom's Hardware > Forum > Brands > Nokia > Nokia 6600 Startup handshake problem
Forum Brands : Nokia Nokia 6600 Startup handshake problem
Archived from groups: alt.cellular.nokia (More info?)
Hi, I've got a problem on my Nokia 6600.
I turn on the phone and it boots up etc, it then has the "nokia handshake"
with the short jingle sound when it performs this, but sometimes it stops
half way into the musical jingle.
I'm on Orange and just after the handshake the Orange logo type screen
appears.
Sometimes it doesn't do it and it plays the jingle all the way but most of
the time it does do it, it's very annoying, any ideas anyone?
Firmware version : v4.09.1
Cheers
Si
Reply to Anonymous
>appears.
>Cheers
>Si
Firmware problem, apparently. Mine does the same. Frankly after the
problems I had till recently syncing this phone to a PC, a spluttering
jingle is the least of my worries.
nl
Reply to Anonymous
- 0 +
I don't know why but it's normal, when you get the prompt to enter pin, let
it there untill the light closes, enter pin and you will hear the entire
melody, it just take a wile for the entire melody to boot and therefore it
dosn't play entirely if you enter pin right when it asks you.
"Dunesea" <ask@privacy.com> wrote in message
news:2qan7kFqg684U1@uni-berlin.de...
> appears.
> Cheers
> Si
Reply to Andy
- 0 +
Have you tried changing the settings on the phone, and turning off the
welcome jingle?
I have a 7600, and the path is:
Settings|Phone Settings|Start-Up Tone|Toggle on/off.
Might be worth a try?
neil
Reply to Rachel
Same here, brand new v4.09.1. The welcome jingle is cut off after less than
a second. And the screen stay white with Nokia at the bottom for a long
while.
> appears.
> Cheers
> Si
Reply to Anonymous
You must have some buggy apps. installed on your phone.They clashing for
memory access..It only happens sometimes only because they all getting
loaded differently..Purify your phone(*#7780#) then all will be well..
"James L" <q2@hotmail.com> wrote in message
news:4143ef1b$1@news.starhub.net.sg...
than
> while.
handshake"
stops
> > appears.
of
> > Cheers
> > Si
Reply to Anonymous
There are 2025 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Surfboard 5120USB "At least 32 MB of RAM"
By hang-the-9, 39 days ago:
Unless you have it setup with a USB connection, you don't need the software.
Best offers
