First Build, Opinions? Advice?
Last response: in Systems
August 28, 2012 4:42:59 PM
Hello Friends,
I finally decided to build my own gaming/standard use comp, just wanted to get some input from you fine people before pulling the trigger. This will be my first build so any input would be appreciated :D
Approximate Purchase Date: In 2 weeks!
Budget Range: 800-900$
System Usage from Most to Least Important: Some gamings, web surfing, media streaming
Parts not needed: Keyboard, mouse, monitor, speakers
Do you need to buy OS: Yes, will be Win 7 64-bit
Preferred Website(s) for Parts: newegg.com/microcenter
Parts Preferences: intel CPU...thats about it
Overclocking: Maybe, in the future if need be
SLI or Crossfire: Doubt it, but i would like to keep my options open
Your Monitor Resolution: 1920x1080
Additional Comments: I dont need a whisper quiet system, i just need parts that will last me a good while :)
And Most Importantly, Why Are You Upgrading: Need a windows pc, too many mac-unfriendly programs
CPU:Intel i5 2500k
GPU:Sapphire Radeon HD 6870
MOBO:AsRock Z68 Extreme4 Gen3
RAM: G.Skill Sniper 8GB DDR3 (2X4GB)
CASE: Rosewill Challenger Black
PSU: OCZ ModXStream Pro 600W
HDD:Seagate Barracuda 500GB 7200rpm
DRIVE:Samsung 22x Dual Layer DVD
More about : build opinions advice
August 28, 2012 5:21:59 PM
If you're not going to overclock it makes no sense to get the 2500K. On an $800 - $900 system I'd suggest something like this:
CPU: Intel Core i5-3450 3.1GHz Quad-Core Processor ($199.99 @ Newegg)
Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($97.55 @ Newegg)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($46.99 @ Newegg)
Storage: Samsung Spinpoint F3 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
Video Card: Sapphire Radeon HD 7870 2GB Video Card ($244.99 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($51.00 @ Newegg)
Power Supply: Corsair 600W ATX12V Power Supply ($51.98 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($22.98 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($99.99 @ Newegg)
Total: $885.46
(Prices include shipping and discounts when available.)
(Generated by PCPartPicker 2012-08-28 13:21 EDT-0400)
m
l
August 28, 2012 7:17:25 PM
Thanks for the reply!
I would like to overclock at some point, probably when im more familiar with the process. Also depending on how much gaming I end up doing.
The only parts Im a little on the fence about are the mobo and psu, not really sure if they are the best "bang for buck"
m
l
August 28, 2012 7:41:43 PM
Your build looks good to me the PSU is a decent one though i personally wouldn't use it. :na:
m
l
