G
Guest
Guest
MY PC is as follows:
Operating System - Windows 7 Home Premium (64 Bit)
CPU - 3.3Ghz Intel Core i5 3500k
Video Card - 1.25Gb Nvidia Geforce GTX 570
Ram - 8gb DDR III
Power Supply - Thermaltake Toughpower 750w
Motherboard - Asus P8Z68-V Pro
I have had my PC now for a good several months, and had no problems with it. For the past couple of days my PC has been just crashing & restarting itself constantly, and I have no idea why.
Now though, it will not even boot up properly. Basically, what happens is I turn the PC on and it starts to boot up. It then restarts itself around 5 seconds later, only to boot up again. It only seems to restart itself the once though for some reason.
The problem is, nothing is going to my monitor whatsoever. It just says "check cable signal" on the monitor, even though the PC seems to be on. I've tried the monitor on a different computer & it works fine, so I know it's not a problem with that.
I've tried taking out the RAM, Graphics Card, PSU and refitting them to see if anything was out of place, and I've also double checked to make sure if all the cables are properly plugged in, which they are.
I'm finding this extremely irritating, as I just can't find out what's wrong with it at all, it's just started happening all of a sudden. I'd rather leave taking it to a technician as a last resort, due to the cost, although I may have to if I can't sort the problem myself.
I'd really appreciate some help with this, thank you.
Ram - 8gb DDR III
