First Build-Need Help
This is the PC build that I wanted to get:
http://pcpartpicker.com/p/fX7h
I used pc part picker to put everything on the same page. I just wanted to know if my CPU will bottle neck my 660 ti that I wanted to get. Any feedback is greatly appreciated. thanks.
21 answers Last reply
More about first build need help
  1. An Intel processor will do you better :)
    yeah ihad the idea of getting the standard i5 2500k but I am on a budget and was looking at AMD and apparently the FX-8150 was the only good cpu other than this one which was comparable to it and only at 90 bucks...I have some time but that is the only think that I was think of. and I would have to change the mobo but I have two builds, one with AMD and the other with Intel.
  3. Whats your budget?
  4. Nw333 said:
    Whats your budget?
    i want to be around the 750 dollar range, and i dont need a HDD because i have a 1TB from my dad. And i can get t the i5 2500k for 160 at micro center down the road. Also, im not looking for the fanciest case, that isnt that important to me.
  5. http://pcpartpicker.com/p/fXN9
    $20 over budget, but since you have a Microcenter near you, you should be able to get the CPU and mobo for dirt cheap. You may even be able to afford the 670 lol.
    thanks man, and also i dont need a optical drive, goona use the one on my desktop now, lol, that is another 20 bucks in my pocket
    that and the 670 puts me around 30 dollars over budget so i just might do that
  8. Puts you right on the budget then:D
  9. Thats awesome. When you get that 670, you will have a killer gaming pc. Will play anything at 1080p. :D
  10. Depends on what your playing. What kind of games do you play and at what setting do you want them at, your monitor resolution will also help.
    now i am not looking to play bf on 1080p and maced setting or anything ut i want a good pc, so to cut down on costs should i get the 3GB 660 ti?
    ill be playing Day Z a lot with friends, i play now but my pc is ***, that will be the main use, but I dont want to limit myself because later on I might want to play bf or other pc titles, im just not sure. I will be playing bf4 on pc though so...
  13. Arma2 isnt the most optimized game in the world lol. Bf4 will definitely require a good card to play on high or ultra at 1080p. Definitely a 670, if you can afford it.
    yeah the 3GB of the 60 ti is 30 over my budget but the 670 will be 70 over...a little soul searching and working hard haha, but do you think the 660 ti willl be able to hold up?
  15. It should, but you might want to check out the 7870 or the 7950 to see if it goes over budget. AMD has already cut the prices on the 7xxx cards by $50 so it shouldnt put much of a strain.
    i looked at the 7950 but the ting was that it didnt compare to the 670 nor the 660 ti in the benchmarks, and ive always had a hard on for Nvidia
  17. Hm. I seem to have forgotten the PSU lol. My bad. http://pcpartpicker.com/p/fY5f
    only 500 okay, i added in a 650, and is this 80+ certified?
  19. Doesnt state on then pcpartpicker site. If you feel unsure, here: http://pcpartpicker.com/p/fY8h
    PSU is even modular. Less clutter more airflow :D
    This Ivy Bridge cpu down below doesn't over clock but it doesn't need to. It will run circles around that AMD cpu not to mention you don't need the after market cpu heat sink and over clocking with IB cpu's doesn't gain you much in regards to FPS. Also these MSI cards come with an excellent over clocking utility so save yourself some $ and take a few minutes to over clock the card yourself.
    http://www.amazon.com/Antec-Three-Hundred-Two-Gaming/dp/B006TVQTHW/ref=sr_1_6?s=pc&ie=UTF8&qid=1346229915&sr=1-6 $58.98 & this item ships for FREE with Super Saver Shipping
    Antec Three Hundred Two Gaming Case, Black
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030 $59.99 FREE SHIPPING 15% off w/ promo code EMCNBHG22 , ends 8/29
    Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1039573 $116.98 save: $8.00
    ASRock B75 PRO3 LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
    http://www.microcenter.com/product/388579/Core_i5_3450_31GHz_LGA_1155_Processor $149.99
    Intel Core i5 3450 3.1GHz LGA 1155 Processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814127697 $299.99 FREE SHIPPING
    MSI N660Ti PE 2GD5 GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
Build CPUs Systems Product
