Need info on computer parts
Hey, I am building a computer. These are my parts I have chosen:
Optical Drive: ASUS 24X DVD Burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204&Tpk=N82E16827135204
Motherboard: ASUS P8Z77-V LGA 1155 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131820&Tpk=N82E16813131820
Memory: CORSAIR Vengeance 8GB (2 x 4GB) http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345&Tpk=N82E16820145345
Video Card: EVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB http://www.newegg.com/Product/Product.aspx?Item=N82E16814130809&Tpk=N82E16814130809
Hard Drive: Seagate SV35 Series ST1000VX000 1TB 7200 RPM http://www.newegg.com/Product/Product.aspx?Item=N82E16822148912&Tpk=N82E16822148912
Processor: Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504&Tpk=N82E16819116504
Power Supply: CORSAIR Enthusiast Series TX750 V2 750W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021&Tpk=N82E16817139021
Case: Corsair Obsidian Series 650D http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006&Tpk=N82E16811139006
Heatsink Fan: COOLER MASTER Hyper 212 Plus http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&Tpk=N82E16835103065
Any help would be greatly appreciated.
7 answers Last reply
More about need info computer parts
  1. Computer purpose and budget?At first glance all I see are an expensive PSU and Case that could go into a better GPU/CPU.
    All components are compatible.
  2. Computer purpose is gaming and multimedia. No video editing. Budget is $1700.
  4. http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=60
    if your going to use this pc as a gaming machine and toss in a few high end gpu the power supply you switched to has 4 12v rails. each one has a max of 20a. depending how the rails are set up it may be fine. but if the video pci power is on one rail only then a lot of the high end cards are going to pull more power then one of the 12v rails. the other ps you had for a few $$ more was a one rail system at 62 amps. should be able to handle the largest gpu without any issues.
  5. Can you recommend a PSU for my build? I'm thinking 750W is overkill, but not 100% sure.
    yes, i think it's overkill,, 650W or even 550W would be sufficient
CPUs Computers Corsair Product
