Dear All,
I have a real problem with my laptop, and so far I'm not getting anywhere. Need real help!!! I will say the long version of the story hopefully anyone can help.
I got a Sager 9262 with 2 x 9800m GTX in slim got it when it was state of the art. About 6- 8 month ago, I started getting crashes, blue screen of death , and the display giving vertical , annoying bunch of vertical lines. Asked sager for help, nothing. asked xotic pc for help, and they suggested swapping the card. That worked, but now I disabled one 9800m GTX, and worked with the other.
Every other month, the screen wont light up and I open it up and swap the cards,, it works.
Last week this happened, and I couldnt get anything. Then after swapping a few time, I got a display, but it also show vertical lines, and in device manger I cant load the drivers, to any of the cards.
The thing is, I still get a display , but it is distorted.
At this point I dont want to get my 9800m GTX power back, I was wondering if I can use any thing do have a normal display just to watch movies and browse, like the intel chipset or downgrading the 9800 m gtx just to give a display.
I got some hope because I am get some sort of display as per the pic attached, and I know I cant buy 9800m GTX because it is not manufactured anymore, and if it is used it will cost as much as a new laptop.
Thanks all.
Thanks all.
