Hi I'm planning on building my first pc and could use some advice on putting together the basics so I can upgrade and build on it in the future (as my budget increases as well ).
Approximate Purchase Date: e.g.: appx. 3 weeks
Budget Range: 600-700 after rebates
System Usage from Most to Least Important: gaming (WoW/SC2), web surfing, netflix, putting my DVD's onto WD player, VoIP
Are you buying a monitor: No (at least not now)
Parts to Upgrade: nothing, starting from scratch as I've been on a laptop
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg/tigerdirect (best price really, but I plan on taking advantage of no interest/payments if over 500)
Parts Preferences: my limited understanding says intel makes the best CPU's right now so I've been leaning that way
Overclocking: Maybe (in the future as I want to learn and try it out, but not necessary)
SLI or Crossfire: Only if needed to meet my needs, I'd like WoW/SC2 to be at highest settings
Your Monitor Resolution: 1024x768 right now, but planning on upgrading in the future 1920x1080
Additional Comments: I'd really like to build a barebones to start to meet my budget and allow some room to upgrade (specifically get a good (250ish) GPU months down the road, but I want to be sure I get a good MoBo/PSU/cooling that will allow for that upgrade.)
And Most Importantly, Why Are You Upgrading: my laptop overheats too much, 3 years old, and I'm out of school and don't need the portable aspect anymore. I'd rather upgrade at my convenience then replace when it dies unexpectedly, as well as being able to play my games at max settings.
This is the start I've put together:
i5-3570K CPU - $229
GIGABYTE GA-Z77M Intel 7 Series Micro-ATX - $105
Azza CSAZ-910 ATX Mid-Tower - $65
Apevia 680-Watt ATX PSU - $65
OCZ AGT3-25SATA3-120GB SSD - $90
Patriot G2 Series 8GB DDR3 1600MHz - $38
Total: $593
I'm not sure what to do for a GPU in the future and really what MoBo will be best in supporting a good future card? Or do I not need a real high GPU (as I know WoW doesn't put much strain on compared to other games) Also thoughts on additional cooling that might be needed or am I alright with the stock? Any thoughts/advice is appreciated!
i5-3570K CPU - $229
Total: $593
