Will this psu be enought to run my system
My system specs are:
CPU-Amd FX-6300
RAM-Gskill-8gb 1600mhz
GPU-gtx 660 non ti
Motherboard-M5A78L
Storage: 2x 7200rpm hdd 1x 60gb ssd
Psu: XFX 550w core edition
Will my psu give enought juice for the system i wish i didnt needed to use any money on my pc for awhile now so last thing i want to do is buy a new psu. All the psu calcs shows about 400-450w requiment but can i trust that? And what happends if my PSU is to low wattage?
21 answers Last reply
More about will enought system
  1. Your XFX 550w should be able to power all that with ease.
    GTX-660's TDP = 140w
    FX-6300's TDP = 95w
    Everything else's total TDP: well under 100w
    NVIDIA's system specs for the GTX 660 call for a "minimum" of 450w, and that's taking into account that they're always conservative (i.e. giving a higher-than-necessary wattage requirement) due to the fact that there's a lot of low-quality PSUs out there that can't actually deliver their claimed output wattage. That certainly won't be a problem with your XFX 550w Core Edition.
    GTX-660 TDP = 140w
    FX-6300 TDP = 95w
    Everything else: well under 100w
    NVIDIA's specs for the GTX 660 call for a "minimum" of 450w, and they're always conservative due to the fact that there's a lot of low-quality PSUs out there that can't deliver their claimed output. That certainly won't be a problem with your XFX 550w Core Edition.
    Well i tought, but how about the psu:s efficiency 550w would feed you 440w if 80% right? but does the calc include that fact. And would i be able to overclock my gtx 660, i read that 660 is voltlocked and can be pushed far without changing the volts so it shouldent take much more power..?
    It doesn't work like that, 80% efficiency means that if your PSU is delivering 80W to your system, it is pulling 100W from the wall. The 550w Core edition is an excellent PSU. I have bought one for my GF. It has more than 500W on the 12V rail and it is perfectly capable of powering the system you mention.
    Oh i see well thats a relief :) but how about the overclocking the gtx 660?
    If you want more performance, spend more $ on your GPU. You could go for 660 Ti. With that said, you don't buy a 550W PSU to use on an overclocked system. Stick with stock.
    well i alredy have this system just upgraded my gtx 550 ti to gtx 660 witch i dont have yet but u mean i shouldent oc my 660 :o?
    No you shouldn't. The gains will be minimal, and I am not convinced you are familiar with overclocking. Just enjoy your system the way it is.
    More than enough power for you to overclock your gpu, and your cpu if you want
    Have you seen the power draw of those Piledriver cores when overclocked?
    That PSU has enough power to overclock either the cpu or the gpu but overclocking both is a stretch. Besides, we don't even know the cooling capabilities of the OP's system.
  10. viktorbkk said:
    Have you seen the power draw of those Piledriver cores when overclocked?.
    Yep
    "When overclocked these chips again show a pretty significant jump in power consumption. When I hit 4.6 with the FX-6300, it jumped around 60 watts at the wall"
    PSU has enough power to overclock both
    Not concerned by OP's cooling capabilities, not telling him to overclock, telling him that his psu can do what you think it can't
    Don't know how I managed to mess that up, here's the link that the quote came from
    http://www.pcper.com/reviews/Processors/AMD-FX-8350-and-FX-6300-Processor-Review-Vishera-Breaks-Cover/Power-Overclocking-
  11. delluser1 said:
    Yep
    If you think its fine to simultaneously overclock a power hungry CPU and a mid range GPU on a budget(yet decent) 550W PSU, then all I can say is that you are entitled to your opinion.
    Will it work? Yes, probably. But just because it would work, doesn't make it a good choice for someone who wants to run a system for years.
    Would anyone recommend it? Only someone who is ignorant.
    To the OP:
    If you really want to overclock your system(which isn't necessary), then get a PSU with 50 Amps on the 12V rail, and make sure you have good cooling for your case and CPU.
    To the OP:
    Ignorance comes from not having a clue, should come back when you get one
    What? Did I hurt your feelings? :lol: :lol: :lol:
    Why would your ignorance hurt my feelings ?
    I truly sympathize with your desperate need to win an argument on the internet.
  16. I dont need to OC anything unless fx-6300 bottlenecks 660 witch it shouldent do. But im curious if i could OC whit this psu in the future without spending 80-100€ on a 650-750w psu. Some benchmarks shows that gtx 660 non ti overclocked could almost reach gtx 660 ti power so that wouldent be to bad.
  17. And my cpu cooler is a zalman CNPS7X and my case airflow is perfect and the gtx 660 twin frozer III should do the job
    Have no need to win and am not arguing
  19. aladin matafakaa
    CPU-Amd FX-6300
    GPU-gtx 660 non ti
    Motherboard-M5A78L
    online PSU calculators have a habit of slightly overestimating the PSU requirements. a XFX 550 core edition is sufficient to power any cpu/single GPU combination including overclocking (aside from a few 7970s).
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=225
    you're fine.
    you're fine.
    Seems like ill be fine thanks for reply !
Power Supplies Components
