I really need help here. I have a test build set up for my brand new gaming pc. Everything is connected, and when I turn it on all the fans are spinning. The problem is that it isn't sending any signal to the monitor. The monitor is set to the correct channel, and it says no signal. I have tried this with DVI and HDMI on two different monitors with the same results. Have I set it up incorrectly? Please help if you can.
And here's the parts that I am using:
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131821
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Graphics Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102987
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
CPU Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
