I use my {family-room} PC to occasionally stream web-videos
to my HDTV, but normally just use PC with a CRT monitor.
Using AMD VisionEngineControl I was sucessful in alternating from one
to the other monitor and even doing "dupicate 1080" from HDTV to CRT (not pretty!)
Until recently, I was able to "hybrid-sleep" my 'dual-monitor' Win7-PC and
then awake without any problems or issues. then something changed
a few weeks/months back .. not sure when or what changed ... grrr..
This problem is driving me to drink ... lol
{the system-specs & config, etc are listed below}
=== PROBLEM ===
So, recently, when I WAKE the PC from a long "sleep" (i.e. overnight), the CRT-monitor
does NOT awaken and remains "black" ... althought the PC is actually fully AWAKE.
NEW : I recently discovered a new symptom,
(which may explain the previous symptom)
--- when I turn-OFF the A/V receiver ...
--- then the CRT-monitor goes to "STAND-BY" & goes dark.
btw: CRT/PC does NOT recover after turning the A/V receiver back-ON!.
(so, the 'long-sleep' may be concurrent with when the TV/rcvr
is turned-OFF [i.e. overnight?] )
My current (annoying) work-around is to temporarily,
set the HDTV and A/V receiver to the mode to display PC output,
..wait a few seconds for display-adapter to perform 'handshake w/HDTV' at which time
the CRT will re-AWAKEN & display Windows7 normally.
... I then re-set HDTV/rcvr back to normal TV mode.
The PC-CRT will now work fine ... (till RCVR is turned OFF)
=== HARDWARE ===
AMD FX-6100 / 8Gb G.skill-Sniper F3-12800CL9D (4Gbx2_1.6Ghz)
Gigabyte 880GA-UDH3 {BIOS: FGj} / { recently updated }
CORSAIR TX650 V2 650W / Windows 7 x64 Pro
On-board VID: Radeon HD4250 drvr:v8.970.100.3000 (7/3/2012)
AMD Vision Engine 2012.0704.122.388 (catalyst 12.6)
==> primary monitor :
PC: D-Sub(vga) to Philips 109S ( 1600 x 1200 )
-- drvr v. 6.1.7600.16385 (6/21/2006)
==> secondary monitor : (occasionally to view netflix, etc.)
PC:HDMI(out) to A/V receiver (Pioneer VSX-1018AH)
--> video pass-through to HDTV (Sceptre X42BV-FULLHD)
I've tried nearly every W7 pwr setting available
and changed all the settings in AMD Vision engine-control,,
Thanks for assistance ..
O.T.
I tried to explain as best I could,
but I'm sure there will be questions, feel free...
