akros Honorable Aug 20, 2012 160 0 10,680 Aug 30, 2012 #1 My external build wont start! everything is connected properly but whe I short the PWRBTN connectors nothing happens! HELP PLEASE
Solution TheBigTroll Aug 30, 2012 Have you tried turning it on and off again? can you also try to connect the power button connectors from the case to turn on the system. did you turn on the power supply?
TheBigTroll Illustrious Apr 15, 2012 14,099 1 42,965 Aug 30, 2012 Solution #2 Have you tried turning it on and off again? can you also try to connect the power button connectors from the case to turn on the system. did you turn on the power supply? Upvote 0 Downvote Solution
akros Honorable Aug 20, 2012 160 0 10,680 Aug 30, 2012 #3 TheBigTroll : Have you tried turning it on and off again? can you also try to connect the power button connectors from the case to turn on the system. did you turn on the power supply? Case connector worked! Thank you so much!! Upvote 0 Downvote
akros Honorable Aug 20, 2012 160 0 10,680 Aug 30, 2012 #4 Best answer selected by Akros. Upvote 0 Downvote
