Yes No
Ads
Hard drive problem?
Forum Windows 7 : Configuration & Customization Hard drive problem?
Hello,
Windows 7 will not re-install to any of my hard drives; also. Windows 7 will not boot unless I use use a software aide from my Hiren's Boot CD. What is wrong? This condition occurred after a power failure. Other computer operating system operations appear to be normal.
Reply to mrelectric
What is stopping you from installing windows? does the install process not find any drives or is it crashing?
Overall power fail could mean anything has fried.
Reply to silverliquicity
You might want to wipe your drive also. Diskpart's clean command should do it. At the very least, run a chkdsk on it.
Reply to Hawkeye22
Tom's Hardware > Forum > Windows 7 > Configuration & Customization > Hard drive problem?
There are 1984 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Moving an operating system
By Pinhedd, 9 hours ago:
You will not be able to drag and drop the files because that will not copy the parts of...
Best offers
Top experts
