n-gage problem, inside
Last response: in Brands
Archived from groups: alt.cellular.nokia (More info?)
tried starting it without an mmc?
if that doesnt work, (im not sure if this works on an ngage) try...
switch off
press and HOLD the green button, 3 and the star button...
and while you are doing that, power the phone on.
hold the three buttons until formatting appears on the screen....
"niloc" <123@123.com> wrote in message
news:7nl6k0ppjkbdo227rq4o2r3d89ddnkbr8h@4ax.com...
> hi
> got an n-gage, when i switch on it is ok for 20 seconds then seems to
> go back to start again, like a re-boot, do not know if it has been
> flashed as bought it s/h.
> if needed i will reply with more info,
> col
Does your phone blink Nokia logo 3/4 times and then reboot?
May be you need to get your phone reflashed. Nokia repair
center will do it for free if you are under warranty.
Where are you located?
-ak
niloc wrote:
> hi
> col
On Sun, 12 Sep 2004 08:14:14 +1000, "Daniel Juhn"
>switch off
>> hi
>> col
hi
pressed all the buttons you said, seems ok now, but had to remove the
mmc card.
could be the trouble eh.
Related ressources
>switch off
>> hi
>> col
hi
i switch phone on,
says "nokia" at bottom of screen.
then picture comes up, then date/time ect, then message in a box at
bottom of screen says" app closed
sysapp"
then back to "nokia" and round again.
this is with the mmc card removed.
col
did it format?
or did removing the mmc simply fix it
just wipe whatevers on the mmc somehow and it should be fine, most probably
a program thats autoloading with the phone...
news:ve48k0tv1qqh69625s18ek6d8o071jp4qk@4ax.com...
>>switch off
>>> hi
>>> col
> hi
> mmc card.
did you format it?
if the three button thing works it should bring up a screen that says
formatting... and take a couple of minutes to complete
news:fkd8k01uri6n1nq86evrtnduq06tfpiiaj@4ax.com...
>>switch off
>>> hi
>>> col
> hi
> i switch phone on,
> sysapp"
> col
On Mon, 13 Sep 2004 07:58:09 +1000, "Daniel Juhn"
>did you format it?
if i hold the 3 buttons down and switch on it just says "nokia" then
"please insert sim card"
even tried the code *#7370#
but this just sits there, is it suppost to re-boot?
realy strange.
sounds like formatting could maybe cure if i could get it to work.
col
i guess the formatting doesnt work on an ngage then...
could anyone confirm?
news:20pbk091f4ouflapcdprk3kn8rrmncii18@4ax.com...
>>did you format it?
> realy strange.
> col
i did try *#7370# with my N-Gage, its work fine
"Daniel Juhn" <j.u.h.n.remove.the.periods@optusnet.com.au> дÈëÏûÏ¢ÐÂÎÅ:41463156$0$2720$afc38c87@news.optusnet.com.au...
>>>did you format it?
>> realy strange.
>> col
i was referring to the green+3+* method...
its different to the "restore factory settings"
"Willy" <willy@someone.msn.com> wrote in message
news:414d7971_1@news.tm.net.my...
>>>>did you format it?
>>> realy strange.
>>> col
Hi all, I am getting the same 'white screen of death', and phone just
writes NOKIA 3/4 times and then shuts down(I have a QD). I bought the
phone 2 weeks back, and it has been troublesome ever since. It got
hanged up once every 1-2 days. Sometimes had to be cold rebooted by
taking out the battery. Is Symbian really so unstable!
Now this WSOD has been pissing me off. I tried safe mode boot by
pressing the abc/pencil key, didn't work. Also the 3 key format
combination( Green + 3 + *)....also didn't work. Will getting it
reflashed is the only option?
Problem is I bought the phone in India, and am currently in
Brussels(Belgium), so I don't know if the warranty is valid or not.
Also don't know any Nokia service centre's here. Will look on net if I
find an address. If the waranty is void, will telling them a story
work( can anyone suggest one).
Please help fast, by tomorrow if I can't get my phone on, then I am
game! I really need to stay connected, very desperate situation.
Thanks in advace,
Cheers,
Mukul.
akmu <akmu@hotmail.com> wrote in message news:<rMT0d.177619$mD.72058@attbi_s02>...
> -ak
> niloc wrote:
> > hi
> > col
On Sun, 19 Sep 2004 20:19:55 +0800, "Willy" <willy@someone.msn.com>
>>>>did you format it?
>>> realy strange.
>>> col
none of these work for me, is it supposed to re-boot?
col
Ask the community
