Sign-in / Sign-up
Intel 2700K integrated problem
  • CPUs
  • Intel
Last response: in CPUs
January 14, 2013 12:09:51 AM
Hello! I am sending my GPU back, so until I get another back I still want to be able to browse the internet and so on but without safe mode i cannot get past the booting screen! I can here the login sound but the screen is just black. Anyone know a solution?
More about : intel 2700k integrated problem
a c 108 à CPUs
a b å Intel
January 14, 2013 1:00:17 AM
is your monitor cable plugged into the integrated graphics port?
and is igp enabled in the bios?
m
l
a b à CPUs
January 14, 2013 1:38:52 AM
Revert back to integrated graphics lol? You've got to do it by going into the BIOS and resetting it.
m
l
January 14, 2013 1:39:21 AM
Yes and Yes. (Plugged in using HDMI)
Do you mean set to default settings?
m
l
January 14, 2013 2:00:11 AM
Just ran it as default nothing changed, ran it as default with primary graphics as onboard nothing changed, ran it as i usually do with primary graphics as onboard and nothing changed.
m
l
a b à CPUs
January 14, 2013 2:24:24 AM
Weird... Could it be the actual display port on your MoBo? It should change, Any kind of adapter you using?
m
l
January 14, 2013 2:48:19 AM
what do you mean display port? what should change? and I am not using an adapter. I just reset the motherboard but that also didn't work.
m
l
a b à CPUs
January 14, 2013 5:47:22 AM
You mean you did a CMOS reset? Are you sure you did it correctly? That should have worked.
m
l
January 14, 2013 6:49:12 AM
yes I did it properly, I shorted 2 and 3.
m
l
a b à CPUs
January 14, 2013 9:22:22 AM
Assume it didn't work and yank the battery for minute.
Did you test all the outputs?
m
l
January 14, 2013 9:42:22 AM
I only have a HDMI and i will try that tomorrow.
m
l
