Hello,
This is my build and i am planning to do some gaming at 1920x1080 ultra settings.
Im gonna list a little build and then would like some suggestions or replacements.
Case-Cooler master storm scout
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119196
Motherboard-Asus M4A88T-V EVO
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131827
Power supply- Rosewill RP600V2-S-SL 600W
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817182032
Hard Drive- Western Digital caviar blue 500GB 7200rpm
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136769
Memory- G.SKILL Ripjaws series 8GB
CPU-AMD PHENOM II X4 965
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103727
GPU- SAPPHIRE Radeon HD 7770 GHz 1GB 128-bit
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102967
Optical drive- ASUS 24x DVD Burner
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827135204
I dont need an OS or monitor.
Appreciate all thoughts thanks.
