Hey guys,
I am working on a build with either a single gtx670 (potential to add another later) or possibly two 560s in SLI. First of all, which of those do you think will perform better? They are just about equal in price coming in at around $400 (plus or minus $20, makes no difference to me).
Second of all, what kind of monitor (size, resolution, any other relevant specs) would work best with that set up? I've really only used a laptop before, and I've bought myself an HDTV before, but I don't really know much about displays.
Can you give some suggestions? I'd give a budget range, but I have no idea what is reasonable for what sizes. I won't need anything to large, probably just big enough to have proper resolution. Probably no more than $200-$300
Thanks guys!
Thanks guys!
