Building Budget System for Guild Wars 2,Need Advice
Approximate Purchase Date: Hoping to get the Parts next week
Budget Range: 750 max
System Usage from Most to Least Important: gaming, youtube
Are you buying a monitor: No
Parts to Upgrade: everything( I am currently using a 5 year old laptop to run wow and such, but I want an upgrade.
Do you need to buy OS: No (As long as I have the retail box version, Im pretty sure I can just transfer the liscense to my new pc then not use it on my laptop anymore, the laptop originally came with vista)
Preferred Website(s) for Parts: all from newegg to keep it easy
Location: City, State/Region, Country - Omaha, Nebraska
Parts Preferences: intel?
Overclocking: no
SLI or Crossfire: Maybe
Your Monitor Resolution: hopefully this rig could run 1920x1080
Additional Comments:This will be my first build, so hopefully it looks good. I know my psu is overkill but I would like to be able to crossfire that 6870 just in case I need to when it starts to get dated. Or crossfire/sli other cards in the future as well.
And Most Importantly, Why Are You Upgrading: I want to be able to play swtor, Guild wars 2, civ 5, total war, diablo three, and steam games at preferably high settings
2 answers Last reply
More about building budget system guild wars need advice
  1. Sorry guys totally forgot to include my build in there. http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=20029905
  2. Go for an i5 3570K and an ASRock Extreme4 Motherboard instead :)
    Z77 all the way! Everything else looks good.
New Build Laptops Systems
