Help on CPU and ssd installation
Hello,
I just recently got a new i5 2500k to replace my i3, I also just got a new ssd. I'm wondering whats the best order to install them? Also do I just pop the old CPU out and put the new one inor do I need to update bios or anything like that? Thanks for the help. Oh and I have a asrock z68 mobo
11 answers Last reply
More about help installation
  1. CPU is a piece of cake. Just swap it and it will work just fine, no drivers or anything. If you are going to reuse the cooler, you'll need to reapply some new thermal paste. Or the new cooler with the 2500K should have some new paste on the bottom.
    SSD is a little trickier. You can either image your current drive to the new SSD and replace it. Or you can reinstall windows on the SSD, which is a little bit more clean, but a lot more work.
  2. You should always update your BIOS when upgrading your CPU or RAM. And while you're at it, get the latest version of chipset drivers for the motherboard and all requisite drivers for your system before you begin your install.
    Install the CPU first, then install a fresh copy of your favorite OS on the new SSD. Don't open yourself up to the headache of trying to migrate your OS to a new drive.
    You got that backwards. The cpu update is harder than the SSD.
    Its not that hard if you know what your doing.
  5. I've done two SSD installs on two different machines. One was a new install and the other an image. I didn't see any issues imaging other than potentially having to shrink your C: drive down before cloning or finding a utility that will do it for you. If you have a lot of stuff installed and not enough time to rebuild everything (it was my work machine), cloning works fine.
    How so? It's Sandy Bridge to Sandy Bridge with no drivers or software involved? BIOS upgrade not needed since 2500K is one of the original SB chips. Hard drive involves some work finding the right uility, shrinking partitions, making sure it comes up as C and not F:, etc.
    You seem to like to argue with me lately about nothing! :)
    Because your always one mistake away from destroying your computers two most expensive parts. We take if for granted, but lots of things can happen when your pulling, a heatsink and cpu.
    And if a guy is on here asking how to do it, then he doesn't have anywhere near our experience.
    Hard drive, on the other hand, is harder to screw up. Though it can be more time consuming.
    That's the fun of forums. Spirited discussion! Often about nothing.
  7. Hard drive clones are one wrong source vs destination selection away from having two blank drives! :)
    True, but you can back up a drive. And there might not be anything important on it to begin with. If a person can't handle data transfer, you sure don't want them messing around with static sensitive and potentially dangerous electronics.
    Thank you for that, Falcon. Of course, "Mycatsdied" probably would not have asked the question if they "knew what they were doing".
    Still going on that one even when I thought I made it obvious I was being sarcastic. Kinda funny at this point. OP asks for installation help and you want to keep trying to figure out which one is more difficult like it actually matters. He intends to do both so the end result is 1=1.
  11. Thanks for the ther help guys... I have installed the CPU and no problems. I also upgraded my GPU to a 660.
    The SSD has been the Pain in the ass. It will not take windowss 7 at all. I have tried updating drivers, and firmware(wont run the update off a cd) but the windows install freezes on extracting files. I can get the computer to recognize the SSD so i think my windows disk is to scratched to work.
    I have a old/new problem though and the reason that Im upgrading these components to start with
    Heres the link to my other poost any help would be appreciated there
    http://www.tomshardware.com/forum/forum2.php?config=tomshardwareus.inc&cat=31&post=380772&page=1&p=1&sondage=0&owntopic=1&trash=&trash_post=&print=0&numreponse=0&quote_only=0&new=0&nojs=0#t2876637
CPUs SSD Intel i5
