Hello I'm building a new computer and I'd like to know what you think of it and will the parts be compatible with each other, So far these are the following specs; (Note: i am building in a small case)
AMD Phenom II X4 965 3.40 GHz Black Edition
CORSAIR 2 X 4 GB DDR3-1333Mhz
MSI 760GM-P23 (FX) AMD Socket AM3+ 760G + SB710 DDR3 MicroATX Motherboard
250Watt PSU FSP GROUP INC
SAPPHIRE HD 6670 1GB GDDR5 Low Profile
Windows 7 Home Premium 64bit
Seagate 160gb Hard drive Sata 2 7200RPM
So will this rig be able to play GW2,BF3,MOP and Crysis 2 at High settings ? And another question is will the parts be compatible with each other because the motherboard has a PCI Express x16 3.0 slot and on the Graphic cards website it says it requires just one PCI Express X16 slot available so does it matter that my motherboard has the 3.0 version ? And also will the PSU be able to power this, I would get the 350 Watt Bronze PSU but its over my budget
Thanks for reading and any help would be appreciated, im planning on ordering the parts Tonight or Tomorrow.
