My psu's real power output
Last response: in Components
Hi all,
I need the help of a psu brainiac please.
I have a POS power supply made by arctic.
Its a 700 watt unit claiming to provide 38amps on one 12v rail.
I want to install a GTX660 graphics card that needs 24amps minimum on the 12v rail.
When I do the maths.
700watt/12v mains I get around 53amps, which is no where near what this psu says it can provide.
When I take the 12v rating and multiply it by the 12v I get 38amp*12v=462watts
So does this mean the psu is actually a 462 watt psu wrongly labelled or am I missing something.
It only shows the combined max wattage on the label 684watts divided over the 3.3, 5 & 12v rails. Max output 700watts.
The 3.3v claims 24amps, 5v claims 30amp and as I said 12v claims 38amps.
Can anyone tell me the "real" 12v amperage I can expect from this unit.
I can't replace it at the moment so would like to know what to expect from it and my upgrade limits.
Thanks
More about : psu real power output
Power supply Authority
In the past different voltages were more widely used. Now the two big power draw components (CPU and graphics) both use 12V. What this means is that modern, good quality PSUs are capable of delivering most of their "sticker" value in 12V.
So a decent PSU of 700W these days will likely have a 12V amperage of maybe 50A+, meaning it should be good for 600W+.
It varies from manufacturer to manufacturer, but you should really be getting 90%+ on the 12V rail.
XFX and Corsair 750W PSUs both have 62A 12V rails, so a theoretical 744W. That's the type of figure most PSUs should have these days, however a lot don't.
To get the sticker value, manufacturers add up the powers from each rail. On a cheap or legacy PSU, this means a huge amount of the power is basically unusable.
Yours should be 79W+150W+456W, for a sticker value of 700W. As you correctly concluded, it's the equivalent of a decent 500W PSU (roughly) though it's probably going to go wrong a lot quicker :)
As for installing a GTX660, they really don't need much power. Nvidia says 24A but thats for the entire system, not the card. The card has a tdp of 140W, it's not likely to pull much over that, even if its got a factory OC.
Related ressources
Power supply Master
For a system using a single GeForce GTX 660 (non-Ti) graphics card NVIDIA specifies a minimum of a 450 Watt or greater power supply that has a maximum combined +12 Volt continuous current rating of 24 Amps or greater and that has at least one 6-pin PCI Express supplementary power connector.
Total Power Supply Wattage is NOT the crucial factor in power supply selection!!! Total Combined Continuous Power/Current Available on the +12V Rail(s) rated at 45°C - 50°C ambient temperature, is the critical factor.
The Alpine 700 Watt Quiet ATX Power Supply, with its maximum combined +12 Volt continuous current rating of 38 Amps and with one 6-pin PCI Express supplementary power connectors, is theoretically more than sufficient to power your system configuration with a single GeForce GTX 660 (non-Ti) graphics card. Whether or not this power supply is actually able to deliver the power stated on its label is another story.
Power supply Master
mangotrees said:
Thanks, that's the reply I was looking for more or less, although it would be nice to know what its real 12v amp output really is, cos I bet its not 38amps at 90% load
I dunno the model number, its a cheapo make, and its not antec, I know antec. Its arctic
The Arctic and Alpine power supplies look exactly the same and I wouldn't doubt they are the same relabeled generic trash.
The only way of determining what it is really able to deliver is to hook it up to a PSU load tester. Doing that would probably result in the power supply's self-destruction when its limit is reached.
The problem of those crappy psus, sometimes with 40-50% load, which will have with your system, that psu is a 450w-500w at the best, that's just fake labelled 700w, will have poor efficiency and high ripple and noise levels, that could lead to crashes, throttling, bsods.
That's why you should never cheap out on a psu, and not just look for the wattage of a one, but also the quality, efficiency,if it delivers what it's promised.
The reason you don't get 700W is that your looking at just the 12V rail. The MAX TOTAL output is 700W. The max of each rail will vary and they may add up to 700W or higher. Just make sure that the total load for each rail isn't exceeded, for the 12V rail you also have to include the power from any drives and your Mobo. The 12A difference you'll have could easily be used up by other components and may push your PSU over the brink.
